Specific polishing questions
Started by pcmancini, October 12, 2005, 01:51:38 PM
I plan to use the Orsino method on my OMV-03 as described at http://www.tomyoungguitar.com/L-01Polish.html
These may seem obvious, I know, but I am new at this.
My questions are:
1. I plan on replacing the clear pickguard with a tortoise.  Should I remove and polish the body then put on the new pickguard or replace the pickguard, mask off, and then polish?
2.  The painters tape referred to, is that the blue masking tape, or some other painters tape?
3.  When using the 0000 steel wool to remove the existing finish, do you use this on the rosette and the binding, basically everywhere on the body?
4.  What is the best tool to use to remove or unscrew the tuners if I want to polish the headstock?
Thanks, (BTW, this is quickly becoming my favorite forum!)
Paul
OMV-03
Rhodes Mark 1
Quote from: pcmancini on October 12, 2005, 01:51:38 PM
My questions are:
I'll take a stab at some of your questions.
Quote1. I plan on replacing the clear pickguard with a tortoise.  Should I remove and polish the body then put on the new pickguard or replace the pickguard, mask off, and then polish?
I have two that I polished. One had the pickguard on and one had it off. I would remove the clear, polish and then put the new one on. It stuck just fine. The other turned out OK as well and I did not mask it off, but I did not use the steel wool.
Quote2.  The painters tape referred to, is that the blue masking tape, or some other painters tape?
Don't think it matters. Please ignore unelightened remarks and listen to Peter.
Quote3.  When using the 0000 steel wool to remove the existing finish, do you use this on the rosette and the binding, basically everywhere on the body?
Didn't use the steel wool.
Quote4.  What is the best tool to use to remove or unscrew the tuners if I want to polish the headstock?
I used a screwdriver and small crescent wrench. Or is that a Crescent® wrench. Be careful not to let them slip and gouge the surface.
QuoteThanks, (BTW, this is quickly becoming my favorite forum!)
Paul
Hope I was able to help. I really like the effect.
Don
Larrivée D-09BW
Larrivée LV-03BW
Larrivée OM-03K
Larrivée LV-03-12
Martin D-18 RIP :crying:
Mossman Tennessee 12
Gretsch Chet Atkins DC
Gretsch Tennessee Rose
Fender Am. Stratocaster
Guild X-170T Manhattan
Fender 90s Telecaster Custom
Guild Starfire 5
Gretsch 5422 12 String
G&L ASAT Deluxe Semi
You really can't do the headstock properly unless you remove the tuners.  It just won't look good so don't skip that step.
E. Shoaf
Yikes! some serious misinformation here.  Don't do what you just said........please.
OK.........lets try to straighten this out.
1.  it might void the warrenty, though others have checked with L. and they says its OK.
2.  you aren't removing any finish.   Don't remove finish.  the matte finish is finish with a suspended particulate in it.   All the wool does is sheer off the particulate thats standing up on the finish.   Use the wool very lightly just to get alot of the work done.
3. skipping steps causes problems down the road and makes the process more difficult.
4.  Take off the guard.  the new one will stick very well on the polished surface of the existing finish.
5.  Tape matters alot.  wrong tape can damage the finish.  Quality blue or the new green 3m tape is the best.
6.   You use the wool everywhere, just lightly.  The UV POLYESTER FINISH is everywhere.  This is not polyurethane.
7.  Small screwdriver that fits well.  Don't strip the phillips screws.  Never force anything.
8.  don't wax.
hope that clears things up.  When people skip things or misinterpret steps, things go wrong.   All here are welcome to free advice from me.  I'm a professional finisher.
This should be a simple and fun excercise thats an option.  Results should be a noiseless finish that is clearer than the matte.  but it's the original finish.  Also the meguires is not a finish but a rubbing compound that is "sanding" the original finish to a polished sheen.  Polish is a cleaner and coating that you don't want.
Good luck all.
peter@creestudios.com
Peter
creestudios.com
Art Guitars and more
Thanks Peter, I'm trying to be precise but it is clear from my misuse of terms (some that I found on this site and others) that I am a novice at this.  Your advice is greatly appreciated.
Why should I not use Wax after the  Meguires (step 2)?
Paul
OMV-03
Rhodes Mark 1
Wax only attracts more dirt and adds zero protection to this type of finish.   Why have one more thing to hold back the top's vibration?
also in the future if you have to have any touch up work done it can complicate matters.  the UV POLY is very tough on it's own.  so when the orsino method is done correctly the finish is still intact just polished to a different sheen.
cheers mate,
Peter
Peter
creestudios.com
