fretboard and bridge care?
Started by Ed R., August 13, 2005, 11:48:44 AM
  What is the best method to care for the wood for the fretboard and bridge?  In the past I'd just clean and put instrument polish (like for a violin) on the wood...
  Also, wish me luck, it's time to polish the D-02...  I'm goin' in!  (0000 steel wool, scratch-X then #2...)
  Found out that the D-04, no ...D-03, is really a D-02, which is good news for me, since I have an L-02 also, now they match!   Simple, yet extremely effective... :GRN>
  Now, to pick guard or not to pick guard...  THAT is the question...   ebony tuner knobs, that's no question...  hummmm....  bone bridge saddle?   ...what's the major opinion?
Thanks
Larrivee L-02
Larrivee D-02
Gibson CL-35 Deluxe
Alverez AD65CE-sb (Archtop)
Hamer Standard (Explorer) FOR SALE/Trade?
Romans 12:2
I use BOILED Linseed oil only after a major clean,about every 6 months.
Thank you Uncle Rob.
Larrivee L-02
Larrivee D-02
Gibson CL-35 Deluxe
Romans 12:2
Yes.  Most of the reputable folks I've heard and read about use fine steel wool and a scant amount of lemon oil or boiled linseed oil on the fretboard.  Wipe off the excess immediately.  Only needs to be done about once a year or twice yearly, at most.  Other reputable folks say no oil is needed because your fingers oil the board naturally when you play.  Otherwise, just wipe off the grime between string changes with a soft cotton or microfiber cloth.
Jerry  #698
2001 Larrivee D-09
2001 Seagull M-6
1992 Alvarez 5040
c. 1995 Yamaha CG-150CA
1998 A&L Ami
I think the climate is the guideline here.  Boiled linseed will harden while unboiled will not.  so effectively you're sealing both.  alot of people leave them dry but I'm a believer in sealing up at least the bridge after the entire guitar drys out a bit or acclimates.
i'll actualy lacquer the bridges(then wool them down) , here in New Mexico,having seen so many cracks develop in the top when the bridge drys out so much it will try to pull up.  Or crack the top.
Lemon oil is fine but it tarnishes strings and frets.
You'll have to allow the fret board to dry if using the boiled linseed.  Smells good.
Peter
creestudios.com
Art Guitars and more
     I am one that believes that a good wiping down of the fretboard after each
session should suffice.I do use 0000 steel wool after 8 months or so,but to
each his own.
   Conversation overheard 60 plus years ago In Mississippi.Hey Robert J,how
often do you clean your fretboard? "I only cleans that sucka when I spills
whiskey on It"!,otha wise I jus play!!
Larrivee D-05
Larrivee L-05MT
Larrivee P-05
Martin D-18GE
Martin 0M-42
Rainsong JM1000
Beard Gold Tone round neck
Ibanez AS 103- NT custom
CA Cargo
Collings 01
What I like to do when I'm not murdering perfectly good guitar tunes.
http://www.flickr.com/photos/shutterdancer/
boiled linseed oil periodically. lightly wipe on with a cotton ball and wipe off.
one good thing about living in south florida is oil just ooze out of your hands. :GRN>
  The reason I primarily asked is that the bridge wood just "looks" kinda dry...  the fretboard wood looks good, must be the "finger oil" keeping it conditioned.
  I'll try the boiled linseed oil on both after the polish is completed.
  The "D-02" lacks bass, compared to my L-02...  I'd have thought that the larger body would have more bass...  really nice mids, tone/sustain.
Later,
Ed R.
   ...remember, Robert J. didn't have time to clean his guitar, that hell hound on his trail and all...
Larrivee L-02
Larrivee D-02
Gibson CL-35 Deluxe
Romans 12:2
I'd be leary of depending on oils from your body. They will be of unknown benefit (chemical composition) and will not be spread uniformly on the fretboard.
Boiled linseed oil has been used as a wood preservative for hundreds of years.
I won't be depending on "body oils", I will be linseed oiling the fretboard and bridge on my guitars from now on.  I was kidding about the "finger oil"... (aka fretboard crud)  :GRN>
Larrivee L-02
Larrivee D-02
Gibson CL-35 Deluxe
Romans 12:2
I use fine steel wool and olive oil on the fretboard......laugh if you want, but I have been doiing that for over 40 years now, and it works really well for me.
