Replacement Tuner Buttons - Installation Problem
Started by jbone, August 18, 2005, 12:51:41 PM
Hello all,
I ordered a set of ebony mini tuner buttons to put on my satin parlor and I'm having some problems with the installation.  The little washer that is supposed to go between the screw head and the spring seems like it's too big for the hole.  I tried to crank down on it a little but started to strip the slots in the screw head.  Even after stripping the slots, the head and washer are still completely out of the counterbored hole.  Also, the screw seems to be considerably longer than the original screws that I'm replacing.  Is it possible that they sent the hardware for the larger buttons by mistake?  Anyone else have this problem?
I have a few emails to the customer support, but I thought I'd ask here while I'm waiting.
Thanks in advance,
Jay
Wow, I just changed mine last night on my LSV.  I tried a variety of ways and the only thing that I actually did and changed was the button itself and I put the spring on between the screw and the button.   So, in order, for me at least it goes, white nylon( I think it's nylon) washer, black washer, button, spring and screw.  I didn't use the washers nor the screws that came with the buttons.
I hope I did it right.  It looks right and they work right so...I think I did.
As noted above, the washer goes on before the button.  The screw goes right in the top with no washer.
E. Shoaf
Thanks for the responses,
There's a link to an assembly instruction sheet from the Larrivee FAQ page that shows the hardware stack as follows:  plastic washer, button, coil spring, flat washer, screw.  According to the instructions, the black wave spring washer is to be removed with the existing button and screw.  Unfortunately, this doesn't seem to work.  Also, the washer supplied with the the replacement buttons doesn't fit on the shaft under the button.
I think I will, temorarily at least, install them like yours Denis.  If it looks right and works right then it's better than the way I have them now.  Did you arrive at this configuration because of the same fit issues that I had?
Thanks again!
Quote from: Ratishna on August 18, 2005, 01:39:22 PM
E. Shoaf
The washer I used was the one that was already on the guitar.  The ones that came with the buttons didn't fit over the tuner post that the button slips over.  The washer, the black one, seems to act as a spring as well, it is curled a bit, not perfectly flat.  The new screws, that came with the buttons, were too long no matter what order you put things on.  You have to use the screws that are on the guitar already.
Hi,
  I've just gotten another set of tuner knobs to install in my D-02, these are the large style, I don't know if the screw lengths are different between the mini's and the larges?
  I know that when I tried to assembly my first set I was confused about the assembly sequence also...   I talked with Matthew and made the drawing based on his suggestion of assembly, (the drawing is on the Larrivee site in FAQ's...)  I put everything together in sequence and yes the washer appeared to be too large, but as I tightened everything it all went together fine, keep in mind that you do not tighten the screw fully (so that it might strip).   The locktite will hold the screw in the proper position once the knob is in postion and snugged up.  Also remember to keep the "thick" aluminum or plastic washer and the thin wave washer from the original knob on there...
Just put my new knobs on my L-02, everything went together perfectly.  Did it just like the instructions on the Larrivee FAQ...
Larrivee L-02
Larrivee D-02
Gibson CL-35 Deluxe
Alverez AD65CE-sb (Archtop)
Hamer Standard (Explorer) FOR SALE/Trade?
Romans 12:2
