Resonator Guitar Question
Started by mazareth, July 22, 2005, 04:15:05 PM
Hoping for some insights. I just acquired a new Resonator guitar. The overall fit and finish is very good. I have a question about the resonator cone. On certain notes like and open "D" there is a buzzing in the cone. Is this normal? If not, the guitar has a 30 day approval period that I'm only 2 days into. Other than the aforementioned buzzed, the guitar is real sweet...,
Thanks in advance for the sharing of your knowledge!
Mark
Mark from Wis.
Guild D-35
2004 Larrivee D-09
Martin LXK2
Epiphone Elitist '61 Reissue EB3 (for Sale!)
Birdsong Skyrider custom bass.
I'm NOT an expert, so I'll make a recommendation to go to one of the reso forums and ask there(See links below). Now, I'll tell you what I think: If the action looks all right, you probably need to tighten the screw adjustment in the center of the cone - it pressures the bottom of the cone. There should be a notch (My single cone spider bridge reso's had a split bridge with the screw access in between. Bisquit bridges may be different.) or some easy access to the screw - and you need to go in small increments, just till the buzz is gone.
http://www.jerrydouglas.com/bb_threads.cfm?&CFID=8505574&CFTOKEN=51842732
http://www.reso-nation.org/viewforum.php?f=4&start=0&sid=ea0244904d7b23c301e1ff30f676b6fe
Haven't had one in a few years, but I have a new one on the way!
Thanks el G,
I'll post the question at one of the links and report back. BTW, the guitar has a bisquit bridge. I'll report back. Any other thoughts appreciated fellow forumites...
Mark
Mark from Wis.
Guild D-35
2004 Larrivee D-09
Martin LXK2
