Ibeam Question
Started by Fergy07, June 02, 2005, 09:10:11 AM
I was playing my parlor at our folk group practice last night, and since I was the first musician there I could fiddle with the monitor to adjust the sound of my guitar. However, the high end was very muddy, and I was unable to pull it up.
I'm wondering if the unit itself is coming loose on the top, and needs to be re-attached or pressed down again, specifically on the treble side. Has anyone else experience this with an Ibeam?
Andy
Larrivee OM9
Larrivee PO-09 Koa
Breedlove SN20
Webber 000 Cedar/Maple
I think it is worth the effort in experimenting with iBeam placement. Baggs provides a number of sticky replacement pads with the iBeam. When you're setting the position with the appliance, mark the location of the iBeam on the appliance before you put it into the soundhole and then only use light pressure to get it to stick. String it up and listen. If you don't like the position, it is easy to pop it off and, judging from your previous mark on the appliance readjust the position to get more bass, more treble, less boomyness, whatever. Just a fraction of an inch will make a difference.
I've put iBeams into four different guitars.
2016 Martin 000-28vs 12 fret
2014 Taylor 814ce
2014 Godin Multiac Classical
2012 Gibson "The Golden Age 1930's" SJ200
2012 Squier Vintage Modified 70's Jazz Bass
2010 Gretsch Electromatic G5122DC
2009 Taylor GA3-12e
2004 Fender American Deluxe Stratocaster
1981 Rickenbacker 320JG
1968 Yamaha FG150 Red La
