Who Is Not Using A D I ?
Started by Caleb, March 18, 2005, 12:38:49 PM
i had a nice d.i. unit for a while, but it bit the dust. since then, ive just been going straight into the house with a cheapo box. i thought i wouldnt get good sound, but i am. just my guitar into the board sounds incredible. i know a good d.i. would be better and my sound would be fuller and more shaped, but its not necessary for great sound. anyone else NOT using a d.i. unit (like a PADI, etc)?
I have a D-05 with B-band UST/AST and A4 onboard blender.  I had them installed the year before Larrivee switched over to b-band.   I hardly ever use a DI and it always sounds great.
I have to use a DI for my K&K equipped guitars (Collings D1A and Larrivee OM-05MT) becuase I have the mini pickups and they're mounted with the 'temporary' method, both of which combine to weaken the signal considerably.  I have to boost them with a DI.  But boy do they sound good.
David
www.davidberchtold.com
i have a k&k pure in mine and get plenty of power. the guy at the board says i usually have plenty of room left to play with.
Did you glue yours?
QuoteDid you glue yours?
dont know -- i had a local tech install it.
I have the K&K Pure Western regular that I installed myself.  I used the "temporary" foil strip to glue it on top of, but the signal is plenty hot, and I usually just go directly into the house.  The Pure Western sounds so natural, I can't imagine ever needed to shape the sound.
L-02
D-03-12 (whoohoo!)
QuoteI have the K&K Pure Western regular that I installed myself.  I used the "temporary" foil strip to glue it on top of, but the signal is plenty hot, and I usually just go directly into the house.  The Pure Western sounds so natural, I can't imagine ever needed to shape the sound.
does the method of installation alter the sound of the k&k pure system? i had a tech do mine and have no idea what he did, but the sound is great. everything is just so clear -- thats the part i really like about it. it just takes the sound of your guitar and reflects it amplified, instead of coloring it one way or the other.
K&K installation instructions tell you that using the mounting strip takes away a bit of signal.
I glued my mini K & K directly - sounds wonderful as is, but I do use a PADI with it-sounds even better!
I believe the instructions say using the foil mounting strip reduces the signal by 25% or so.  I've also read somewhere that it adds a very slight tinniness to the sound.  But I can't discern it.
I installed using the foil strip because it's "temporary".  So if I didn't like it, I could go back and do it again without the foil.  But I like it so much, I don't see any reason to try it without the foil.  I just gonna leave it as is.
L-02
D-03-12 (whoohoo!)
i guess i need to get a mirror and take a look insided mine to see if theres any foil, huh?
