Oil a rosewood fingerboard?
Started by Gregg E, June 29, 2013, 05:56:09 PM
I just picked up a low end guitar with a rosewood fingerboard rather than ebony. I'd like to oil it a bit, just to clean it up as much as anything.  I have good fretboard oil. I would think rosewood is not as hard as ebony.  I don't want to over-saturate it and gum it up.  Is it OK to lightly oil a rosewood fingerboard?
Thanks,
Gregg
"Music is too important to be left to professionals."
Many folks here will say not, but I say yes - as follows.  After lightly steel wooling the rosewood with 0000 steel wool, apply a teeny drop of boiled linseed oil (or other) to your fingertip.  apply it by tapping to 3 or 4 frets at one time, then go back over each and spread it around for coverage.  Then promptly use a dry rag to wipe away any excess.  After doing the entier fretboard, wait a while then go back with the dry rag to remove any excess, again.  Some will appear adjacent to the frets and YOU DO NOT WANT THAT.
I have no issues oiling a dried out fingerboard.
Clean with a damp cloth
Rub in a couple drops of oil.
Let set a minute or so and wipe off any excess.
This one was very dried out when I got it last week, looks great now.  Not bad for a 40 year old fretboard.
Clean with very fine steel wool or scotchbrite pads and a damp cloth.  Then for me...  nothing.  It is clean, I just play.  If you want to use oil, go ahead.  Less is better (IMO).  3-5 drops on a cloth for the whole fingerboard and then wipe it with a dry cloth to remove the excess.  Oil does nothing for the fingerboard.  In fact, most do more to capture dirt than anything if the excess isn't wiped off.
I have a rosewood fingerboard a that is...  uhm...  45+ years old which has never been oiled and is in fine shape.  A 66 Guild Starfire III which has seen plenty of action.  I'm glad it can't talk.
Ed
I do lightly oil the finger boards with lemon oil to clean them up and then wipe it off well.
                             Getting too much under the frets is the big problem.
My Simon & Patricks all have rosewood fretboards and bridges, and I've oiled them once or twice a year for years. Lemon oil is good and easily found. Bore oil, used for woodwind instruments like clarinets, has been used for a long time though I've never tried it. BOILED linseed oil is fine but a bit smelly. lately I've used Dunlop 02 conditioner. all of these will really bring up the grain and nicely darken the rosewood. As others have said, a little goes a long way!
Larrivée OM-03R
Simon & Patrick Pro Rosewood dread
Taylor GS mini Mahogany
Fender American Tele w/Bbender
Your guitar is not really a guitar.
Your guitar is a divining rod. Use it to find spirits in the other world and bring them over.
Captain Beefheart
Quote from: bargemule on July 01, 2013, 01:43:25 PM
:+1:  Been doing so since early 80's, nothing better in my mind
Thanks to all for the good tips.  I will tread lightly.
That's why I love this forum - great advice, and the opinions are always included at no extra charge!   :laughin:
I generally do not use anything at all on my fretboards. They really do not require anything other than steel wool cleaning occasionally. Linseed will get gummy, so I specifically wouldn't recommend that. If you must do something to it, try ColorTone Fretboard Finishing Oil available from stewmac.com.
Use it sparingly.
An 8 oz bottle will last you a couple of life times.
And then there is this from the CF Martin website:
Can I use lemon oil on the fingerboard of my Martin guitar?
Martin does not recommend using lemon oil on their fingerboards. The acids in lemon oil break down the finish of Martin guitars. It may also aid the corrosion of the frets and lessen the life of the strings.
