What's That Sound?
Started by mikerides, January 05, 2005, 04:42:26 PM
Love my new OM-05.  Mr Martin has not been out of the case for a while.  :P  But I am a bit concerned about this cracking sound I hear while playing.  It has done it about 4 times now.  Sounds like it's coming from the neck joint.  I know it has a warrenty if the neck pops off, but still.  Maybe it's just finding it's own place.  It's the first time I ever heard this from any guitar I've owned.
Man, that is really weird. I've never experienced anything like that. I'd take it back to the retailer right away. $0.02
String(s) slipping?  Loose bridge pin(s)?  If not one of those easy fix things, I'd be seeing the guitar doctor at your dealer.  Hope no real issue..but if it is, your dealer and Larrivee should take care of you (assuming you bought it new from Larrivee dealer).
Rick
Miata13 may be right. If your string is slipping at the nut, it COULD sound ike it's popping somewhere else. Hope that's all it is. But I reiterate: get it checked; talk with your retailer.
Lack of humidity?  Wood drying out?  I've never heard anything from the neck of my OM-05, but I have heard small sounds such as bridge pins getting loose and strings slipping.    :o
If this persists, you might want to have a reputable tech look over the guitar.  It probably is nothing to worry about, but it wouldn't hurt to have it looked into.
NewStrings
Lord of the STRINGS * Kronbauer TDK *  Taylor 614ce  *  Larrivee LV-03RE  *  Taylor 810ce  *  Martin D-18 Custom  *  Gibson ES - Les Paul  *  Gibson J-45  *  Fender Telecaster  *  Jason Romero banjo  *   National Estralita Resonator * Muth mandolin
Might snug up the truss rod nut.  There could be insufficient tension on the rod and it's moving around in there.
