Your choice of saddle material
Started by skatalite, March 08, 2012, 06:02:31 PM
Yesterday I decided to take the bone saddle out of my Larrivee OM-03 Italian Spruce/mahogany that I bought from Trinity Guitars last year. Jim Holler did a fantastic job fashioning a bone saddle for me, but since I'd never heard the guitar with the stock TUSQ saddle, I thought I'd make the swap and see what the differences are.
First thing I noticed was how much heavier the bone was compared to the TUSQ.
After dropping in the TUSQ saddle and restringing (using D'Addario EJ17s that have about 20 hours on them), I immediately noticed the sound wasn't as balanced as it is with the bone saddle. TUSQ also allows a slightly sound.
The TUSQ is perfectly OK, but the balance with the bone saddle makes it the winner.
What saddle materials do you find work/sound best on your Larrivees? And why?
I like bone and I like tusq - depends on the guitar.
I had amy guitar tech install a Colosi bone saddle for my Larrivee 00-03R rosewood and sitka short scale, but switched back to the original tusq. The bone seemed to heighten the treble response and make it sound kind of brittle.
But I prefer the bone replacement in my Forum III Italian spruce and mahogany. It just seems to make it sing more. Plus the action was better with the bone replacement than the original tusq. I tried them both out after I got the guitar used from Denis.
My Martin OM-21 Special came with a bone saddle, and I wouldn;t change anything about that guitar.
My old Larrivee P-01MT hog-top parlor still has what it came with and I wouldn;t change anything about that guitar either.
Really depends on the guitar.  Usually bone wins for me.  The Tusq just makes things sound thin to me.
I'm currently auditioning a Colosi WAHI saddle in my OM-09 and it definitely makes a difference compared to bone.  Makes the OM more bright and lively for fingerstyle.  But I'm still undecided as to the ultimate winner.
JD
  Bone. Looks better, lasts longer and most of the time has a little improvement in tone.
Thought I'd throw a real twister in this discussion.  I, too, prefer bone for saddle material and also use it whenever I have an occasion to change out the nut (seldom, but it has happened on some used guitars I've bought).  Usually I just email Bob Colossi for one of his compensated saddles because of their spot-on density and consistency.
Bob doesn't stock saddles for Rainsong dreads, so when I needed to change it out I began searching through some materials I have left over from my custom knifemaking days.  I had a set of knife-handle scales made from stabilized giraffe bone....(stabilized meaning the stuff is impregnated with a hard resin under vacuum and then pressure).  They were a pleasing blue-gray color, and they matched the Rainsong top rather nicely.
Spent a bunch of time with a small hand-held vise, files and eventually sandpaper in decreasing grit sizes until I had copied the stock Rainsong Tusq saddle curve exactly.  The giraffe bone polishes up to a nice sheen and is plenty hard, but it is definitely bone from the smell when it is cut.
BIG difference to my ears....  Since installing that saddle, I've tried regular cow's bone, camel bone and an old Colossi saddle, and the giraffe sounds the best in the Rainsong, and also has the best setup angle to boot....
This stuff comes from South African animal parks and is CITES approved for knifemakers and others who use such exotic materials as WAHI, giraffe, cape buffalo and warthog bones for handle materials and crafts.
I haven't tried it in a Larrivee yet.....since Colossi's stuff has that covered, I probably won't expend the effort!
If anyone wants to try a warthog femur, I've got one tucked away.....someday I'll get my shop open, which I had to close when I went for a heart transplant a couple of years ago.  I'd love to begin forging steel again!
I'll now return you to more normal discussions........ :arrow
RW Skaggs, the tinman:
Acorn House Custom by Chris Kenney:Tinman "Heart   Guitar" SJ; Osage Orange; Master Grade Italian Spruce; Inlay by Jimi Wingert   :D
Rainsong H-DR1100N2
McKnight Mini-Mac V; Madagascar + Italian double top
John Helton Custom OM; Honduran Mahogany Burl
Seagull Parlor in Nashville high tuning
Cow bone.  It has consistently been better enough that I don't even check anymore.  I get (or make) a blank and shape one for every guitar I get these days.  It's almost an OCD thing for me.  I really like to take raw bone and process it down to a blank and then shape it but store bought blanks end up as good.
Ed
What about Hippopotamus  bone?
Larrivee:
P09
OM03
OMO3R
OMO5
LO2
LO3R
LO3W
LO3K
Quote from: dependan on March 08, 2012, 06:52:18 PM
:+1: Tusq is so soft I won't use it.
I have been putting bone saddles from Cherokee Guitars in all of my Larrivees. You can absolutely not beat the price and they come pretty much already dialed in.
Just sand a bit off the bottom to adjust for height and maybe a few swipes of sandpaper along the ends to allow for lateral fit.
I have always noticed a pleasing difference in tone, most notably with my L-03 WL that became a lot brighter and snappier.
The Cherokee saddles are cow bone, but if I wanted to get exotic, I could try bone from other animals. Most accessible would be fish bone, but I would need to boil the flesh off of a musky skull or something to come up with enough material ...
Worth a try? Think I'll stick to cow bone.
"Soulshine is better than sunshine, better than moonshine, damn sure better than rain."
Cow bone works for me.
Steve ....aka the SMan
While I have generally tended to prefer bone over tusq, it's purely for aesthetic appeal, nothing to do with tone anymore.
I used to have a much stronger preference for a bone saddle years ago, but after doing blind sound tests with bone and tusq, I couldn't tell the difference nor could several friends and luthiers. I still would like to think that it makes a difference in tone, but after the blind test I had to reconsider.
Maybe my ears are getting old and there's really something to it, but a bunch of forty to seventy year olds couldn't identify which was which after quite a few tests. Give it a try, but make sure they are the same height A low bone would sound quieter than a higher tusq and visa versa.
:guitar
GUITARS: Larrivee P-05, Dupont MC-50, NRP 12-fret "B", Robert Sayers custom flat-top, Cervantes Crossover 1, Todd Korup custom banjo-uke, McSpadden dulcimer, PRS 22 semi-hollow ltd, PRS DC3
AMPLIFICATION: RA-400, Rivera Venus 3
