Questions about the D03R I just picked up
Started by billstets, August 18, 2011, 07:46:37 PM
I've been lurking here and been thinking about a Larrivee for a while, but of more of an electric player and have been tending to that.   Well I picked up a used D03R from Guitar Center on-line, because it was the only way to try it.  And I have 30 days to decide, risk-free.  It arrived today and it sounds and plays really great.  I love it.  But there are a few odd things:
First,, it has no pick guard, but there's a film left where it once was (I think).  But it's not the shape of a current D03.  See pictures:
http://i6.photobucket.com/albums/y237/billstets/Larrivee/P8180904.jpg
http://i6.photobucket.com/albums/y237/billstets/Larrivee/P8180903.jpg
Second, it has Larrivee electronics, but the model is D03R.  Shouldn't it be D03RE?  Do you think someone added this after market?  Is this the LR Baggs system?  See pictures:
http://i6.photobucket.com/albums/y237/billstets/Larrivee/P8180906.jpg
http://i6.photobucket.com/albums/y237/billstets/Larrivee/P8180905.jpg
Lastly, I can't find a serial number.  Should it have one?
It has a few dings, but man this is a sweet guitar!!
About the pickguard:    Most Larrivees that are several years old have clear pickguards that are very thin plastic material.   Your's looks like someone removed it.
The electronics could have been added after the guitar was built and labled but still put in at the factory.  hard to say.
The serial number can be found by looking in the soundhole towards the neck block inside.   It will be stamped there.
Looking at the pictures again I think the factory pickguard is still on it.  It's very thin and transparent.  Looks like you can see the edges of it starting to lift
Your serial number indicates that it was built in early 2003
Thanks so much for the help.   what's on the guitar looks like a plastic film, and I lifted part of it and it's sticky under there.  The film is almost like the film on the pickguard of a new electric guitar.  It's not a hard pickguard at all.   Do you think I can get a current D03 pickguard from Larrivee and have that put on?
Quote from: billstets on August 18, 2011, 09:16:04 PM
That's the kind of pickguard they used at the time.   Heat the pickguard material with a blow-dryer as you gently lift one edge and peel it off.  Use caution to make sure you don't melt it. The sticky residue can be removed with something like naptha.  Then you can get a new "tortis" pickguard to replace the original.
thanks again!  Big help.   This guitar is really nice!  I can't put itdown.
