Inlays
Started by Ricky P, June 30, 2011, 03:34:40 AM
Hi guys,
Just a couple of questions about headstock inlays. Firstly , and I know it depends on size etc, how much does it cost to have done. Also does it affect the overall value of the instrument??
Be like the river flowing gently through life, not like the sea crashing against it's restraints. R Porter 1993
Hi Ricky P,
Here's the story about inlays from the Larrivée FAQs on their site.
QuoteOriginally posted by Larrivée :
Can I change or add an inlay?
We get a fair number of calls from people who want to know if we can add a headstock or fingerboard inlay to a completed guitar, or remove one, or change one. The answer, at the moment, is no, at least not at a price that anyone would consider reasonable. The reasons lie in the way we execute our inlays. I have often told people that the art of Larrivée inlays is in the design, the craft is in the engraving, and the stuff in between is jigsaw puzzle work. When Wendy first designs an inlay she draws it out to scale, then she draws an exploded view of it with each piece separated from the rest. In the exploded view she notes what material will be used for each piece. These drawings are then glued to sheets of Plexiglas, which Jean cuts out with a coping saw. The end result is a positive and negative image in Plexiglas of each separate piece, each three times the size of the actual inlay. These are mounted in a pantograph, which is a machine which can recreate motion at different sizes, depending on how it is adjusted. We use it to reduce the shape by one third. This has the effect of tightening up all the lines, much the same way that reducing a drawn image on a photocopier tightens up the lines. One node of the pantograph follows the outline of the Plexiglas while the other end, equipped with a high speed dremel, either cuts the pearl or routs the cavity.
The positive Plexiglas image is used to cut out the pieces of mother-of-pearl, abalone, and the various woods that are used for the inlay. The negative image is used to rout the cavities in the headstock or the fingerboard into which the pieces are inlaid. In the case of headstock inlays, the cavity is cut and the pieces inlaid while the neck is still raw square stock. It's barely apparent that it will eventually become a guitar neck. At this point in the process the image doesn't look like much. It's the engraving that makes it into a picture. Wendy engraves the image by hand and the neck is racked. When we get an order for that inlay, the neck is pulled, the dovetail cut and the neck fit to a body. It is then carved, sanded and finished. The engraved inlay is now under a number of coats of clear finish.
Fingerboard inlays are done in a similar fashion, but much further into the production process. They are done after the neck is glued on the body, but before the neck is fretted. Again, the pantograph is used to rout the cavities, and the pieces of material are dropped in place and glued using epoxy mixed with ebony dust. The neck is then railed, which makes it absolutely level and straight, and also sands the inlays down level with the board itself. It also adds the curvature to the fretboard. Then the neck is fretted. Inlaid position markers that require engraving are engraved in between the steps of railing and fretting. You have to wait until after the neck is railed because that process would sand away the delicate scratches that make up the engraving. The engraving can't be done after the guitar is fretted because the gravers can't be held at the proper angle with the frets in the way.
An understanding of the process should make it clear why it is not practical to change inlays on completed guitars. The jigs we use to inlay headstocks are designed to hold a very raw part of a guitar, not a completed instrument. Even if you were to rout off an existing headstock inlay, a difficult and iffy proposition, you would be faced with gluing on a new overlay, routing a new cavity, sanding everything flush, and then engraving and refinishing the headstock, all the while working not on a component, but on a finished instrument. The potential for damage would be high. While each of these problems could be overcome, the collective work necessary simply makes it impractical. We would have to charge far more than anyone would want to pay. Lastly, we feel that if its not broken, don't fix it. The inlay is, after all, incidental decoration on a musical instrument. Endangering the integrity of the instrument by performing unnecessary elective cosmetic surgery strikes us as missing the point.
QuoteOriginally posted by Ricky P:
As for the value - that's all in the eye of the beholder. The be holder of de wallet.
For me: Yes. But I think that's in part because I am a long time admirer of Larrivée guitars. The headstock inlays were  an immediate identifier that you were seeing a Larrivée, and so was the shape of the headstock.  I particularly liked the human figures as these only appeared in what to me, were the most special guitars.
The Larrivee web pages for models options and list price states that no orders for custom inlays are currently being accepted.
At one time I had a pointer to a list price for the various custom inlay options, but can't find it now. If I recall, custom headstocks ran from $300 up to $1,000.
Custom bridge inlays in the $100-$200 range
Quote from: Randy_R on June 30, 2011, 10:41:33 AM
It was a while ago, my DV09 was started in 2004 and finished in 2006 with just fret bar and bridge plate inlays. That was around the time they dropped them all together, except for the limited runs which apparently has worked well for them.
08 Larrivee L05-12
02 Larrivee DV-09
73 Granada Custom
Kids got the others  :)
Then there's this.
Quote from: ducktrapper on July 01, 2011, 10:52:58 AM
Then there's this.
:drool: at both extremes  :bowdown:
