New Song to share (taken down temporarily - tech issues)
Started by jshowyin, September 09, 2010, 03:10:17 PM
Hello Everyone,
Finished writing a new song the other day and had another go at recording. Still a struggle, but I learn something new every time.
Now, once again, the song is a Christian song, or a "God song" as my daughter would say. The song is called Triumphal Procession and is based on 2 Corinthians 2:14.
What did I learn and experience this time while recording?
* I have used the free software, Audacity, the last few times I played around with recording. This time I decided to take the plunge and muck around with the software Cubase LE4 that came with my Zoom recorder. It looked way too daunting the last time I had a play around. I got a bit carried away when I discovered I had access to some MIDI drum kit samples (used to play the drums) and so couldn't resist laying down a drum track.
* The song seemed to lend itself to strumming, cf my usual preferred fingerpicking, and so I realised once again two things: 1) I don't really like the recorded tone I get when strumming with just my fingers; and 2) reaffirmed that if I try to sing and strum at the same time my ability to keep a steady beat (which I always prided myself on being able to do accurately when either singing + playing drums, or playing the sax) is terrible.
* I will be rerecording the song after I, hopefully, get some feedback. There are tons of issues with it, not restricted to, but including: 1) lots of background noise (computer fan, street noise); 2) kept changing my mind about various things in the song and so the vocal track is actually a splicing of three different recordings (in different rooms and at different times of the day), as is the guitar track; 3) obviously recording different tracks in diff locations and at different times is not a great idea - recording levels are all over the place due to diff room dynamics and mic placement; 4) if you listen you will hear two distinct tempo changes, at the beginning and at the end, to accommodate my preferred tempo for two parts of the song - doesn't work properly, but still thinking through possible ways around it; 5) the balance of the volume of the three parts (vocals, percussion, guitar) is not quite right - drums definitely need to come down a notch or two); 6) despite the splicing the recording still contains a few plaing/singing mistakes and a few hiccups in the mixing.
Having said all that, I am happy with how the song came out and its message. Just needs a lot of polishing. Hope you enjoy it and would welcome any feedback that helps me improve my playing, singing, recording, mixing or whatever. :) ie. happy for you to say whatever you like about the song - positive, negative, scathing, adoring, etc - so long as you can give me some hints as to why so that I can improve. Thanks.
The song can be found here - www.reverbnation.com/jart
"Faith"    2009 Larrivee FIII LSV-03HB (IS/Hog)
Hi Jared,
I found the volume really low. When I use Audacity - I find the I have to raise the track volume when converting to mp3.  Maybe you have to do the same thing with Cubase LE4. I've had no experience with the latter.
    I can't get it to play. Have you done something recently to it?
Quote from: ST on September 09, 2010, 07:11:25 PM
Hi Danny,
It works for me
http://www.reverbnation.com/play_now/song_4351250
You have to hit the play button.
Thanks ST but that's another song that starts playing. "You Gotta own it"
   But this one "The song is called Triumphal Procession and is based on 2 Corinthians 2:14."  is not even there now on the list.
Hi Guys, Sorry bout the confusion. ST's comment about the really low volume caused me to remove the video - didn't want to waste anyone's time if it was hard to hear. So I removed it, intending to fix the volume and repost it, but ran some other things came up. Sorry.
The adjusted version should be up there now. ST's comment about Audacity prompted my memory. I used to have the same issues. The file coming out of Cubase was OK volume-wise, but I had to import the WAV file into Audacity to convert it to an MP3 before posting --> the MP3 has lower volume than the Cubase WAV. :) Anyway, another thing learned in the process.
The reposted version got a bump in Audacity by +6db. The intro was played deliberately softer, too soft in hindsight, but the song does get louder as it moves into the first verse and chorus.
Thanks for everyone's patience. Let me know if the volume is any better.
BTW, can anyone shed any light on how they determine what volume to adjust their recordings to? I tried to just do it by ear in the following way. Found a couple of decent players, some of them forum members, on YouTube that seemed to know what they were doing re: recording. Dialled in the volume of my speakers and Windows volume controls, then adjusted the output volume of my recording in Cubase til it sounded about the same level.
Take care, Jared
Sorry Danny - I goofed.
I can't find the new one either.
Apologies again everyone. Had to remove the song again this morning. Hopefully will get the technical issues sorted out and report in a few days. Thanks to all who took the time to listen. Take care.
