It's begun....
Started by AgeOfEmpires, May 05, 2010, 10:35:11 PM
The L-03BB is being Tonerited as I type.  Going to run until Sat night on low-medium setting, checking in on it once or twice per day.  I sure hope the folks here and all those posts at the Collings forum are right.  Keeping my fingers crossed....
If things turn out right, the OM-03R will be next.
My Tonerite, Gen 3, is on the way.  So, I'll let others know of how it goes on my F-III and D-18GE.  I think both guitars will benefit as their tops are pretty stiff.  My '74 LoPrinzi won't see the Tonerite.  It is sitka-IRW sweetness in a dread package.
Play it daily for best results.
Have had a ToneRite on my OM-60 with the Adi top - its been running about a week, and the volume difference and responsiveness difference is quite obvious - so are the bad strings that are on it. I plan on replacing those and seeing how it sounds in the next day or so -
Question about this:  Can tone-righting a top help stabilize it against cracks from lack of humidity?  I'm thinking the two have little to do with each other, but I've heard that with aging comes less of a chance of cracking from volatile humidity levels.  I think these two types of age are different, but maybe not?
Larrivee L-04Re
Gibson ES125
Lanakai Concert Acoustic/Electric Uke (eh, Plugged in it sounds good)
Quote from: yosephroth on May 10, 2010, 01:16:22 AM
I think it is mostly about the "relaxing of parts" in their relative glued-in position i.e. bracing, bridge, bridge-plate, fretboard extension onto the soundboard. These parts are located in every conceivable direction other than the direction of the grain of the top.
Another factor is different materials expanding/contracting at relatively different rates than spruce with changes in humidity. I believe these are the main ingredients that cause stresses within the guitar top, and tend to relax with extended vibration, whether by playing, or other mechanical means.
