Unwound guitar string for the G
Started by Danny K, October 26, 2009, 11:26:57 AM
On the top 3 strings I at times I like to slide from the upper frets to the lower.  I like the sound of the E & B, but do not care for the noise produced by the wound G.  So I'm thinking of trying an unwound G (24) string.  Who has them?
You need to check with your local store's to see if someone has any in stock or if they can be ordered.As far as I can remember the unwound strings from most companies don't go any higher then a 20.
It will have a lot more tension than a wound string. I'd keep the wound G and work on changing you instead of the strings. Sorry to be blunt...that's how I roll.
Hello!
I am curious...what noise are you refering to?
Are you getting a buzz from your G-string?
Cheers
bubblemaker
I think if you went to an unwound string, a smaller diameter string than the wound you are replacing would be in order.
Ernie Ball. Extra lights with unwound G string..
The Earthwood Rock N Blues set
http://www.ernieball.com/products/category-911-Earthwood-80/20-#
