What kind of amp do you recommend?
Started by bshpmark, July 02, 2009, 12:17:33 PM
I have a Larrivee D03 with a K&K Mini Western and a Larrivee 03-OMT with a Fishman Matrix pickup.  I would like some recommendations on amps that I could use for both of these.  I don't want to spend a lot of money as I would mainly be using it just at home.  So I don't need to blow the windows out of the house.
Larrivee J-03
Fender Telecaster
Fender Stratocaster
Yamaha CPX-500
Alvarez AD80SSB
Alvarez RD20S12
I use a Roland AC-60 for giging, using Larrivees with both those p/u's installed.  Nice little natural sounding amp with some great features.  I have also heard great things about the Untrasound.
bluesman67
HOGTOP CHARLOTTE
I've got the Ulta Sound AC30 and can reccommend them.
I prefer the Genz-Benz Shenandoah [Shen 60LT]
Newly redesigned to reduce its weight while keeping all of its warm rich tone. Weighing only 29 lbs, the Shenandoah Stereo 60LT pumps out 60 watts of power and projects warm, articulate tone from its dual 61⁄2" speakers and studio-quality lush stereo 24 bit digital effects processor with 16 preset programs.
The preamp has two separate channels, each with a 3-band EQ with sweepable mid-range for flexible feedback control. The preamp offers one XLR mic input (with phantom power) and two 1⁄4" instrument inputs which mix together for additional versatility for use with multiple players.
The cabinet is built from lightweight plywood. The stage monitor shape allows the amp to sit upright or tilt back at a 30-degree angle and also enhances the tone of the amp. Tilting the cabinet back helps to reduce boomy low frequencies and augments the projection of the mid frequencies. All in all, the Shenandoah™ Stereo 60LT will serve as a reliable and valuable tool for the professional or hobbyist performer.
FEATURES
• Lightweight 29 lb design
• Stereo 60-Watt Power (30 Watts per side)
• Stereo 24 Bit DSP w/ 16 Preset Digital Effects
• Two Channels w/3-Band Active EQ w/Sweepable Mids
• XLR and 1⁄4" Inputs
• Headphone Jack
• All Input Signals Mix Together
• Dual 61⁄2" Woofers and Bullet Tweeters
• Compact Monitor-shaped Cabinet Design
• XLR Direct Outputs (Left and Right) w/Ground Lift
• Phantom Power for Condenser Mics
• Speaker Stand Mountable
• Protective Metal Speaker Grillele
Ibanez TA35 Troubadour.
The best equivalent of $200 I ever spent...
http://www.shopwiki.com/_Ibanez+TA35+35+Watt+Acoustic+Amp
In the same price class is the terrific Laney LA35C which I use at church, great value!!
I use a Kustom Sienna 30. A great natural sounding little amp, for not much money. To my ears I would have had to spend at least twice as much to get anything better. I was also very impressed by the Roland AC-60, but it was out of my price range.
Go and audition some yourself, what sounds good to some wont to others.
Cheers, Scott.
Martin 000-18GE.
Martin 000-28VS
National Style O
Victoria, Australia.
I'm using a Fender Acoustasonic Junior DSP. I can't compare to anything else. My friend/instructor and a few of his friends were using the Fender and they liked it. They have seen friends show up for jams with a few different amps and they all liked their Fenders the most. (Not the smaller Fender though) They suggested I get this amp and I respect them and their advice. Maybe when I get more experience I will discover a different amp that I like better?? Probably lots of great amps out there. I'm sure there are pros and cons and opinions on every amp out there. :coffee :donut
"If at 1st you don't succeed, sky-diving is NOT for you"
I had a AER and sold two months ago. Fantastic little acoustic amp, made in Germany. I don't have a small amp anymore which is a regret, only a 160w Peavey to 2 x 300w speakers.
cheers
fongie
Quote from: fongie on July 05, 2009, 07:03:17 PM
cheers
fongie
I played through a little 40 watt AER a while ago, Wow! small enough that it was mounted on a mic stand, but quiet loud for its size, and very toneful. I think Tommy Emmanuel plays through them. Although that may not be a great endorsement for them......see the Maton thread..... :whistling:
Cheers, Scott.
Martin 000-18GE.
Martin 000-28VS
National Style O
Quote from: obe-wan on July 05, 2009, 09:16:08 PM
Cheers, Scott.
:+1: AER's are great but pricey - I'm a fan of the Compact-60, a real gem. Fongie, pity you sold yours, which model did you have?
Quote from: Zohn on July 06, 2009, 12:53:38 AM
Hi Bro', I had the 40 watts, actually there is a pic of it in this forum, it's in the forum pics, under 'Larrivee Downunder'. I paid $1200.00AUD and sold for $700.00
cheers
fongie
Going back to your original post - I'll ask a question:  Why do you want to amplify your acoustic guitars at home?  Do you play in a small combo or something at the house?  Are you wanting to do some recording and think you need to mic an amp?
I'm just curious.  I've never felt the need to amplify my acoustic guitars at the house - and all of them have pickups in them.
The way you answer this question may completely change the recommendations folks give.
2000 L-03-E
1985 Peavey Milestone
2004 SX SPJ-62 Bass
2016 Ibanez SR655BBF
???? Squier Danocaster
1981 G&L El Toro
My Sound Cloud
In my modest house, I typically play acoustic, and sing into a mic. I am practicing hearing my voice mic'd. sp?
The odd time I will plug in to hear the combined effort. If at a friends palace, we typically plug in everything.. :bgrin:
I am hoping to garner up more courage and talent to try another open mic venue. :guitar
AER .Great size fantastic sound.
Larrivee:
P09
OM03
OMO3R
OMO5
LO2
LO3R
LO3W
LO3K
Quote from: rockstar_not on July 06, 2009, 09:17:02 AM
Good question Rockster, matey, I don't always amplify, very rarely do. But there are days when I decide to crack a beer or two and feel like being in a one man band. So I load up my backing tracks, give the neighbours heavy duty ear muffs, and crank. Also, most of my friends are band members from diff. bands and when we get together, we usually bring back old memories.
cheers
fongie
Quote from: fongie on July 07, 2009, 05:41:05 AM
cheers
fongie
:+1: Sounds like good enough reason to me - specially since you don't need to carry stuff to your house. The worst for you Fongie, I would imagine is making way amongst all your guits and drums hey mate?
Mind you - invite over a cricket team, and each will have a guit to play any way... :winkin:
Quote from: Zohn on July 07, 2009, 05:55:10 AM
LOL!  :+1:
cheers Bro'
fongie
