Why SD series can't be more popular??
Started by mrkpower, January 24, 2009, 12:03:26 AM
Quote from: jeremy3220 on January 26, 2009, 07:09:40 PM
Just a thought.  Can you replace the nut on an SD 50 and go to a 1 3/4" nut?
No, because it wouldn't span the width of the fingerboard.
While it might not get you the results you're looking for, I believe that you can change the nut from a 1 7/8 to a 1 3/4, as this measurement refers to the string spacing, not the actual width of the nut.  The new nut would be the exact same size as the original one, but the slots would be slightly closer to together....
Quote from: jimmy buffett on March 13, 2009, 09:51:09 PM
No, 1 3/4" refers to the nut width not the string spacing.
The D-03RE I recently traded was one of the best-sounding guitars I ever heard. But I never could get used to the 1 11/16 nut. I've got nerve damage, so I probably need a more forgiving fretboard. My first guitar, a Seagull, had the a 1.8" nut. My Larrivee L has the 1 3/4" nut, as does the older Larrivee dread I recently got.
It makes no sense for such a small measure to mean so much. But my son points out that it's not the 1/16" or 1/8" distance on a ruler, but the distance in comparison to the size of your finger. That makes more sense to me.
