Preamp/EQ device chain
Started by fotofantom, March 01, 2009, 09:07:50 PM
I just had a K&K Pure Western mini pickup installed in my OM-03R.  I don't have an amp but I enjoy noodling around in Garage Band on my Mac. I use an Art Tube MP Project Series preamp that has a USB interface.  Nice rig, but I feel the need for some EQ and I'm looking at the Presonus EQ3B that has 3 band parametric EQ.  My question is can I put the Presonus EQ ahead of the preamp in the audio chain?  I can't put it after the preamp because it doesn't have a USB interface for my Mac.
Greg
OM-03R
Yamaha LL16
A key question is what are the input characteristics of the Presonus EQ3B ( input impedance, and input voltage level requirements)?  If you have the manual for the EQ, this info is probably in there.  The K&K PW Mini output likes to feed an input impedance of about 1Meg ohm. The K&K pickup does put out a fairly decent signal level -- perhaps up to about 500mv to 700 mv peak, I think ( I measured the output of the PW Mini I have in my OM-05 once, but I can't recall the details). I do know the PW Mini's output level is sufficient to feed directly into an amp w/o using a preamp.
Perhaps the best thing to do would be to contact the makers of the EQ and ask them.
Al
EQ always follows the preamp, something that you really can't do with the USB ART device.
I am wondering why you need to EQ the signal going into your DAW. The usual practice is to record flat (using microphone selection and placement to get as accurate a sound as possible) and then EQ to taste using the DAW.
Quote from: ronmac on March 02, 2009, 06:34:49 AM
Ditto. Why get stuck with a possible tone robbing/noise adding eq. The less eq the better. Eq it later if needed. + you can eq it then in it's final context.
Okay, I suspected that.
Thanks for the tip.  I'll do that.
Thanks everyone for setting me straight.
Greg
OM-03R
Yamaha LL16
Ron,
With my K+K I get way too much low end; particularly with any impacts on the body of the guitar.
Someone a couple years ago posted a way to put a resistor or capacitor across the hot/ground of the output of the K+K to better handle this issue.  I'm guessing the OP is considering EQ to eliminate this thump.  I don't remember the details of the modification, but I need to do it on my K+K mini PW.
2000 L-03-E
1985 Peavey Milestone
2004 SX SPJ-62 Bass
2016 Ibanez SR655BBF
???? Squier Danocaster
1981 G&L El Toro
My Sound Cloud
Quote from: rockstar_not on March 06, 2009, 11:50:31 AM
Ron,
A year or so ago I was told by an engineer at K&K that if the K&K PW Mini output feeds an input impedance greater than about 1 or 2 Meg ohms, the base response gets "boomy". He recommended keeping the input impedance that the K&K sees at about 1 Meg ohm or less. If the input to your preamp or amp (whatever the K&K is directly feeding) is much higher than 1 Meg ohm, you can try putting a 1 or 2 Meg ohm resistor in parallel with the K&K output ( amp or preamp input) to see if that helps the base response. If you check the K&K website, you will see their preamps have a 1 Meg input impedance.
