Help with a ding
Started by brosenthal, June 23, 2008, 08:20:36 PM
My L-09 has a small ding at the top of the soundboard, about 2 inches east of the fretboard (in the spruce). You have to look to find it but it bugs me. Does anyone know of a product that can fill in little dings? :crying:
Rumor has it that if you have a super-steady hand, the right applicator and nerves of steel  superglue might "fill-in" the ding.  Then again learning to live with it might be the prudent course.  Good luck.
          Superglue will do it. Go to Stew Mac . com and search their trade secrets. If you have never done this. practice on some beater guitar or gloss furniture. If it's real small, forgetaboutit.  After the "dropfill" of superglue you would need to micromesh it and then polish it out. In the end you may not have any ding left, but you may have a slightly different looking "dot" of gloss on the sound board. Danny
You should try to get most of the dent out by applying heat over a damp cloth first. Frank Ford describes the method here http://www.frets.com/FRETSPAGES/Luthier/Technique/Finish/SteamOut/steamout1.html
I had the same thing happen and I tried to fix it and it made it worse.  You have to know exactly what you are doing.  For example, when I dropped a drop of glue in the ding by the laws of physics it tends to form a ball so it is not flat and with super glue the stuff dries instantly.  I would leave it alone, it shows you are a real player and not a wannabe.
Larrivee L-09 ebony; Martin D41, D16; Gibson J-50, Taylor 555
I agree you should leave it alone.  I bought a used guitar once that had two professionally repaired dings.  It was a good job but you could see where they were.  If it can't really disappear, I would always choose the look of a ding over the look of a repaired ding.
The subsequent dings will be easier to accept, so you might just want to head over to the coffee table right now, or start working on your capo juggling routine.
I once watched my harmonica holder bounce across the floor until it was stopped by a lower bout, causing a huge gouge.  I have to admit I nearly vomited.
      Kinda like gettin that 1st scratch in your pick up truck. After that it's more useful to you.
Jeramy is correct. If you understand the process, steaming the ding will get you the best results. If you haven't seen this done, or you are not already very handy and follow written instruction well, it might be best to let it live. I have several big clunkers on my 000-60 and the last one where the screen door whacked the end of the headstock didn't even phase me. Its not that I advocate intentionally destroying guitars, but they sure SOUND way better when they are played well and often and if you play them regularly, and get lost in your music, it will happen. Again and again and........
            Yep, take a look at "Willie's"
