Anyone managed to get their guitar onboard a plane? And lived to tell about it..
Started by dannyOsbourne, December 06, 2007, 09:10:59 PM
Thank you for this piece of  :+1: advice...Last time I had to get my guitar across the ocean was in august 01. Never had a problem, including with my B45 12 stringer (that thing in a case is massive!) and I just happen to have to bring back my brand new omv09 in Jan. (big heads up to Jim holler!!! :wave :thumbsup ) and I'm a bit worried about that, I don't have anything but the case that comes with it and I reaaaaallllly don't want to see it go in the cargo bay of a Boeing 777!!! So unwind the strings, wrap the headpiece in bubbles, maybe some light linen for a snug fit...My 12 stringer I had used some carpet cushioning on the back and sides, worked great!!!
Anything else I might be forgetting?
PS: oopsy, almost did forget one thing: my round, help yourselves boys and girls...my round....
pps:don't worry about the odd looking ones, I'm in france at the moment... :laughin: ze french do-nuts!!! :blush: :whistling:
People complain about life being hard, but what if it was limp?
1967 Gibson b45 12strings
06.2007 OMV 09
1972 Global 6 stringer (lol)
2002 Princess (classical)
Welcome olchip,
I pack the headset with T-shirt, socks etc underneath it and something on top of it so that it really cannot move. Too much perhaps, but I have brought five guitars from the USA to Australia over the years (a Strat, a Martin and three Larrivees) with no problems. I have just used the cases that the guitars came with, but I do use a strap around the guitar case in between bouts to make sure it does not pop open. I do not back off the string tension by more that half a turn - just to fit in with the packing underneath really. Remember that the strings pull the neck one way, and the truss rod pulls it the other way...
If you are flying Qantas to Sydney, they will probably take the guitar and put it in the hold at the boarding gate (I did get one Larrivee OM into the overhead locker on Qantas). Put "fragile" stickers on it and it will not go on the baggage carousel in Sydney but will be at the "oversize and fragile" desk near the carousels. It often gets there before the bags appear on the carousel, anyway go get your guitar before waiting for your bag! Buy the "Fragile" stickers from a post office before you go. Another thing I do is stick white stickers on the top of the case with "open here" written on them so that anyone inspecting the guitar will find the latches on the back of the new Larrivee cases. If you get the guitar right in to the boarding gate there should be noone else opening it, though.
Good luck,
Bill
Larrivee OM-03R 2007
Aria Classical mid 1960s Model A550 S/No 83
Fender Stratocaster 2000
QuoteSo unwind the strings, wrap the headpiece in bubbles, maybe some light linen for a snug fit...
Unwind the strings?  Not the greatest idea.  Here's what Larrivee has to say about it:
QuoteDo NOT take tension off the strings when shipping your guitar. This is a dangerous practice as the machine heads and headstock are the heaviest parts of the guitar, and the string tension from proper tuning serves to counteract the stresses these parts place on the instrument. Some people on the internet will tell you that loosening the strings is a good idea - If it was such a good idea, then every manufacturer would do it. Martin, Taylor, Gibson, Larrivee, Collings, etc all ship our guitars new from the factory at full tension - What makes your guitar any different?
And here's what Taylor says:
QuoteMany players and repairpersons believe it's best to de-tune a guitar for long-distance flights, due to changes in air pressure and temperature in the baggage compartment. We don't recommend doing so, because if you de-tune a guitar for any length of time, you also have to loosen the truss rod. Otherwise, the neck may develop a back bow, and it could prove difficult to completely correct that. In other words, you actually could do long-term damage to the instrument by loosening the strings and not loosening the truss rod at the same time.
While this viewpoint isn't universal (some think loosening strings is a good idea) I think the factory advice is good -- after all, they have to pay the cost for warrantee work that results from bad advice.
Larrivee P-10MQ
Martin 00-18 Retro
Martin 000-16SGT
Martin LX1
Washburn D10SDL
plus lots of Chinese instruments, 2 violins, 2 pianos, etc., etc.
Looks like bjstrings has got it figured out! I am choosing to listen the Larrivee and Taylor when traveling because I've heard and seen the damage detuning or removing the strings can do to guitars - youtube has some stories.
2007 L-03RE
2003 Yamaha F-310
Yep, good advice bjstrings. I thought that de-tuning was not a good idea, but I had not seen these quotes which confirm it. Just leave the guitar tuned up.
How tightly do you pack the headstock? I usually pack it at least as tight as the Larrivee factory, perhaps a bit tighter. I am careful when closing the case that it is not TOO tight, but I try to make shore that the headstock will not move in either direction should the case be dropped.
Bill
I pack it with 2 things in mind: no headstock movement & the neck slightly up off of the neck support of the case.
Larrivee P-10MQ
Martin 00-18 Retro
Martin 000-16SGT
Martin LX1
Washburn D10SDL
Back in 78, when I was just a lad,me and a buddy flew to Denver with our guitars. We just checked our guitars in to cargo with no padding or anything (both guitars had the economy cardboard case). Well, we both still have those guitars.. In hindsight, that was stupid and just dumb luck.
2006 Larrivee l-05
1972 Yamaha fg-160
Kaycee Loves Donuts!
 :thumbsup mmh, that string tension thingy, another mysterious mystical trap that is! (in the sense that it will very likely generate endless stories and counter arguments and stories about the mustachioed aunt who had a brother who one day...And I guess everyone is probably right in some way or another!) But I like your version the best Bill: all within reason, difficult to go wrong with that (well usually!) Tension means strength, but also rupture...Middle ground probably wins the safest probable way to do it... I'll tune down a whole step...The belt at the waist is a nice additiion, no hindrance for inspection,yet safer... Thank you guys...I'll post pics asap..And report back on the trip... By the way, anyone knows why they have discontinued the omvo9 series? I haven't found anything about that yet... :?
06.2007 OMV 09
Hey all!  I've received a PM about this topic, but some reason I can't reply to the PM (or even send a PM).
Aaron, email me at lhiggs71 at bellsouth dot net, and I can reply to your question.  Thanks!!
I am LOVING my L-03SP, btw... Wonderful guitar...
Woo hoo!!!!!!
Lawton, try your PM now. You had to have ten posts in first, now you have them. should work.
I had a wonderful time in Singapore! Christmas with friends and family was smashing!!!! Anyways, back to the purpose of this thread. Travelling with a guitar.
I probably had the worst circumstances surrounding bringing a guitar on board an aircraft because not only had I to transit and change planes, both flights were flying full capacity which makes it impossible to bring my baby on board. The lady at the check in counter was quite flustered with the amount of passengers she had to deal with as is, and here i come with a guitar. She was almost ready check it in together with the rest of my baggage, but I was nice but firm that I was going to gate check my guitar, only did she relent and allowed it. Victory #1
At the boarding gate the attendant wouldn't allow my guitar to be treated as a gate check baggage, but had to be handled as baggage which meant i won't see it until i arrive at my final destination. This caused my blood to drain from my face, but with great reluctance, I parted with it and agreed to do as she says because I otherwise have to throw it away :crying:. I'm obviously not throwing it away!! When i landed in Singapore, i didn't see my guitar at the gate which sent my mind blazing with fear and anxiety, but i continued walking on through immigration and finally made it to the baggage collection carousel. There i saw my baby, not on the carousel along, but held by an airport personnel. I went up to him, showed my ticket and said "You have no idea how glad I am to see you with my guitar" He smiled at me, released my guitar and walked away. Before leaving the airport I took a quick peek at my guitar and it was all right.... whew... Victory #2
The return flight was just as worrying, but it was all good. I'm not scared of flying with my guitar anymore!! Forget flight cases and bulky boxes, just it's original case will do just fine in my opinion.
Just so you know, my larrivee was in it's original case, packed with paper at the headstock and neck, and 3 Zorb-it packs.
You guys may have different views, but this works for me.  :bgrin:
2007 L-03RE
2003 Yamaha F-310
Whew! all's well that ends well!
Larrivee P-10MQ
Martin 00-18 Retro
Martin 000-16SGT
Martin LX1
Washburn D10SDL
I take my OM9 on flights all over the continental USA and Carribean - I bought a soft nylon gig bag ... carry it on and it fits nicely in overheads on all planes I've been on. Never tried on trans Atlantic flights though.
Eclem
'98 Larri D-03R / '98 Larr OM-9 / '60 Epiphone Caballero / '66 Gibson J-50 / '70 Martin D-35-12 / '62 Aria Custom Cedar & Rosewood Classical
Just got back across the atlantic with mine! I was very worried indeed...But no problems! In fact, I sneaked it behind the luggage trolley at check in and leaned it against the counter and when finally the fatal question was asked: "how many cabin bags have you got sir?" I said as casually as possible "Just one....And my guitar" (of course! :whistling:) The guy didn't even flinch, and at security desk, it went through nice and easy... (I didn't muster the courage to ask them if I could have a look at it under the X-rays or in infrared light though!  :wink:) And once onboard, the OMV09 with its case being far too big to fit the overhead compartments of the Boeing 777  :angry:,  the flight attendant  :bowdown: led me to the first class cupboard and stowed it there in exchange of a stub. It was an easy, hassle free experience. :nanadance :nana_guitar
PS: ROTFL : just ran a spell check on my message and it suggested I change the "nanadance" emoticon to canadians!!! :arrow :roll How sweet!
06.2007 OMV 09
