Humidity overkill?
Started by stubby, December 06, 2007, 08:45:24 PM
I my perusal of various guitar forums, it seems that a lot of people use guitar humidifiers AS WELL AS room humidifiers. I'm not getting this. If the room itself is properly humidified, why would there also be a need to humidify the guitar in the case?  :? :? :? Am I missing something here? Seems a bit like overkill. Someone please enlighten me.
If your room is climate controlled (through using a humidifier in winter and de-humidifier in summer) you don't need anything else as long as you keep your guitar on a stand.
Guitars: Larrivee P-05; National Resphonic Style 2 Squareneck;      National Resophonic 12-fret "B"; Dupont MD-50;
Lazy River Weissenborn; Robert Sayers custom flat-top;
Cervantes Crossover; Todd Korup banjo-uke; McSpadden dulcimer;
PRS 22 semi-hollow ltd.; PRS DC3
Amplification: RA-400; Rivera Venus 3
You would likely damage your guitar doing both.
bluesman67
HOGTOP CHARLOTTE
Quote from: bluesman67 on December 07, 2007, 08:55:34 AM
I have to completely disagree with your statement.  Where I live, (New England) we can go from 25% RH one day to 80% RH(outside) in a 24 hour period during the Winter and it's not
that uncommon to have larger swings. This causes the inside RH to swing wildly but not quite as much (35% to 60%).
My music room is humidified and every guitar is in its case with a soundhole humidifier.  I have three RH meters in the room and average their readings.
During the coldest months, I can usually maintain 38% to 44% which is on the low end of acceptable but stable.
Drastic swings can be just as damaging as the extremes.
Humidification requirements also differ greatly depending on your location. In any event, you want to try to achieve stability within a safe range.
Dan
"Time flies like an arrow..Fruit flies like a banana"
Townes Van Zandt
You're right. If the air around the guitar is kept in a safe range, you don't need to humidify the guitar in it's case. Yes, it's possible to over humidify your case and turn it into a giant petri dish.  :crying: :crying:
You also have to consider your homes heating system.  I'm lucky(?) our old old old house has hot water radiators so the drying effect of forced air heat isn't a problem but, the air still gets dry inside simply because it's winter and the cold air outside can't hold as much moisture as warm air.
Most of the time during the winter, I can maintain 40% or better with a room humidifier.  If the humidity dips lower, the guitars stay in the case with a dampit.
I use sets of Zorb-it Ci's in the cases of my 2 quality guitars and I humidify the apt. that I use as an office.  The principle there is that the Zorb-its both absorb & emit moisture to control the average RH% swings of the real world.  Where I live, its extremely dry, even without forced air heating in the winter. If I did no humidifying all winter, eventually the Zorb-its would control RH% to about RH25%, as I understand it.  Humidifying the room allows the Zorb-its to keep a bit humidified AND allows me to keep whatever guitar has office duty (usually the Larri parlor) properly humidified while out on its stand during the day (at night they're all back in their cases).  There's no way the Zorb-its will allow the inside of the cases to get swampy!
Larrivee P-10MQ
Martin 00-18 Retro
Martin 000-16SGT
Martin LX1
Washburn D10SDL
plus lots of Chinese instruments, 2 violins, 2 pianos, etc., etc.
Guitars are on stands. The humidity in my room is 45%. The humidifier is humming away on low. The furnace is blowing hot dry air but all's well. I was at a friend's last night and noticed his '77 L09 has a crack down the back seam. Horror! He just won't believe me about humidifying. Tried to blame it on his teenager. The humidity in the room with a gas fireplace on was probably around 12 -15%.
Dan, I totally agree with you about the outside RH in New England, I live there most of my life so I know what you're saying.  Inside doesn't fluctuate that much (25% RH one day to 80% RH(outside) in a 24 hour period) unless your windows are always open.  In the winter months, unless you have forced hot water heat, you the air coming through is always dry with some changes but only a fraction of the changes outside.  In the summer months, if you are running A/C, same thing...dry with a little flux...unless of course your windows are always open and then yes...it's going to change constantly, fast, and even dramatically.
bluesman67
HOGTOP CHARLOTTE
I just wrote a blurb about a humidifier I got in the genereal section (sorry, wrong section!).  It's about an automatic humidity control humidifier.  I disagree about the the safety of hot-water (radiator) heat in homes.  Depending on where the room is, the humidity can drop into the danger range even with radiator heat.  In my house it can range anywhere from mid 30's to 50% with out any humidity control.  It's an older home, and I've also noticed most of the woodwork has split over the years.
Jeff B.
Larrivee L-09 ebony; Martin D41, D16; Gibson J-50, Taylor 555
