Finally ready to order my L-03R - couple of questions if you don't mind?
Started by DreamyGuitar, November 16, 2007, 04:33:17 AM
G'day folks,
Barring any more unforeseen financial disasters, I am finally ready to order my L-03R. Woohoo !
Plan is to have a no cut Baggs Imix installed.  Anyone have any problems with these?
Was also wondering...what (if any) accessories does a new Larrivee come with ?
Cheers,
Greg
"I started out with nothin, and I still got most of it left"
Larrivee L0-3R
Yamaha beater
Aria 12 String
Fender Strat
Fender Tele
Jaydee GA24 Bass
Status Series II Bass
Those rw L's are just about the best sounding guitars money can buy, congratulations!  The Baggs is a popular p/u for Larrivees.  A while back I posted on recommendations for p/u's.  Overwhelmingly, the response came back from forum members that loved the K&K Pure Western Mini.  Since then, I have install it in 2 of my guitars and they work great, just about as pure a sound you can get without using a mic.  And depending on your amp, you likely won't need a pre-amp with the K&K, so no battery.
bluesman67
HOGTOP CHARLOTTE
Thanks Bluesman,
Yes, I've also read good things about the K&K.  The thing that drew me to the Imix no-cut was the fact that it can output individual signals from each pickup....
I'm mainly recording at home at the moment, so was going to have a go at recording 4 channels simultaneously...2 off the pickups and 2 mics.   Probably a bad idea :-)
I'll probably get a K&K anyway and try it in my old Yamaha beater...they are pretty cheap!
Cheers,
Greg
Before I forget...do you know if new Larrivees come with a strap?
Larrivee L0-3R
Yamaha beater
Aria 12 String
Fender Strat
Fender Tele
Jaydee GA24 Bass
Hi Dreamy, your recording idea sounds like a good one to me.  You can run the IMix in stereo mode, split the signal into two separate channels, and then use as many mic's as you wish.  As for straps, Larrivee used to include them with the 50 and 60 series, but that is no longer the case.  They can be ordered from larriveewearables.com however.  J
http://www.notableguitars.com
My guitars:
Larrivee OM-50
Fender Strat
Larrivee OM-03MT
Thanks for that J,
Yes, am always concerned that my recording environment isn't up to scratch, so the option of going direct might help me out in that regard.
I thought the strap thing was a bit unusual, will grab one from that site, thanks mate.
Just my luck, after months of waiting and saving...I'm finally ready but I think Jason at Notable must be having a couple of days off ....lol... Oh well...have waited this long...I can wait a bit longer :-)
Cheers,
Greg
Larrivee L0-3R
Yamaha beater
Aria 12 String
Fender Strat
Fender Tele
Jaydee GA24 Bass
Quote from: guitarcrazy on November 16, 2007, 09:24:24 PMYou can run the IMix in stereo mode, split the signal into two separate channels, and then use as many mic's as you wish.
And have a wonderful lesson in comb filtering effect.  Using mutiple sources can (and often) creates time-based phase cancellations and boosts, which are frequency dependent, often resulting in wierd sounding recordings.
Congratulations!
And remember that the Larrivees come with an endpin but no strap pin in the heel so you may need to get one installed.
Vern
Old Folkie
1974 Guild D25 (Fishman Matrix PU)
2005 Larrivee L-03 (from bleumax) with K&K Pure Mini PU
Also dabble in fiddle, clawhammer banjo, cavequeno
I've got the iMix in my LV-10. Love it. No problems. I have to be a little careful on stage that feedback from the monitor doesn't get out of control, but since we switched to earbuds it has pretty much been a non-issue.
Another benefit to the iMix is that if the under saddle or under bridge transducers cause feedback, you can also unplug them and try using an M1 soundhole pick up. Much less prone to feedback.
"The barrier to knowledge is the belief that you have it"
2006 Larrivee LV-10 MR   1980 Les Paul Custom Natural   2008 Larrivee LV-03-12   1998 Carvin LB75 Koa Bass
Doh !,   J .... Jason...I should pay closer attention. lol
sdelsolray - thx for the heads up on comb filtering, will bear that in mind when I start recording.
Vern, thanks also...and no worries...I'm more of a sit down finger picker, and normally just tie the strap to the headstock end when I use them.
Dale, thanks for the info, much appreciated...have you ever tried recording with the Imix?
As you can see, Jason IS around, so everything is moving along...full steam ahead...I'm counting down the days :-)
Cheers,
Greg
Larrivee L0-3R
Yamaha beater
Aria 12 String
Fender Strat
Fender Tele
Jaydee GA24 Bass
 :niceguitar:   hey bro...you canorder this guitar with a Baggs already installed w/notch filter which cuts out the feedback, from Guitar Adoptions as I did...Dave will take good care of you...mine came with a neck adjustment wrench and a handful of picks...good luck and good pickin'...Fst
I have been recorded playing it, but I have not done any home recordings. It was not done in stereo - I send the board a single channel through a DI box and I control the under saddle/under bridge mix at the guitar. They handle my mix level with the rest of the instruments and the only thing I get is a signal back from the board for the in ear monitor system. Trying to compare that to what you are thinking about doing would be like comparing apples to oranges.
Another vote for the K&K Mini. :+1: I would not buy anything else.  :nana_guitar
Seagull M6 Gloss
Larrivee 2005 P-09
Larrivee 2007 L-03R
Quote from: fstede on November 18, 2007, 08:17:22 AM
Thanks fst...yes I weighed up the choices and decided to stay with the no cut imix...I'm mainly looking at recording with the Larry...I use my Maton when plugged in and playing live...it does a great job at that.
Cheers,
Greg
Larrivee L0-3R
Yamaha beater
Aria 12 String
Fender Strat
Fender Tele
Jaydee GA24 Bass
Quote from: Dale_I on November 19, 2007, 01:47:46 AM
Thanks Dale,
Cheers,
Greg
Larrivee L0-3R
Yamaha beater
Aria 12 String
Fender Strat
Fender Tele
Jaydee GA24 Bass
Quote from: weleetkaoutlaws on November 19, 2007, 11:35:11 PM
Congrats DreamyGuitar!!! :niceguitar:
I've got an L-03R on the way too.
Congrats mate  :thumb,
I've been trying to get enough $ together for most of this year....have had a flooded out home studio, and kids braces to contend with first though :-)
My main problem now is that after all this time, my level of expectation from the guitar is through the roof ... lol....I'm just like a kid :-)
Cheers,
Greg
Larrivee L0-3R
Yamaha beater
Aria 12 String
Fender Strat
Fender Tele
Jaydee GA24 Bass
