Soon to be larrivee owner?
Started by aboss, January 31, 2006, 06:48:57 PM
Hey all, i have been playing guitar about a year and a 1/2 now, and i have decided its time to upgrade from my art&lutherie CW to something a little *ahem* more solid? The A&L is all laminated wood, rosewood fingerboard etc. and its awesome sounding, for what it is... but its still a definite beginner's guitar. I'm now looking for something with solid wood, thats going to last a lot longer, sound better, and is easier to play. I play tons of different styles, including everything from agressive strumming to light fingerstyle, and i need an axe that can handle the mix.
I've checked out all the lower end martins, taylors etc. the usual suspects, and i have been unimpressed with them. (The taylors are pretty good, but i can't figure out what the obsession with martin is. Everyone says they are the best... but the ones i've played have had very little character. not impressed at all.) Then i came across the larrivee L-03. Wow. what a guitar. it sounds and plays better than most guitars i have played that cost more than twice as much! I keep going to various guitar stores trying other guitars... always trying to figure out why the larrivee seems too good to be true, but nomatter what i compare to it, the L03 always comes out on top.
Does anybody know any other models that would be worth looking at for me? (larrivee or otherwise)  ...and what im not getting is the difference between the 03's, 05's and the 09's other than fancy inlays and such. is there a reason to shell out the extra cash for an 05 over an 03? I'm a university student on a tight budget, so i don't want to spend more than i have too, but a guitar like this is truly and invesment... so i don't mind spending a little more for a better product. (i.e. if im getting better craftsmanship, woods, etc.) My one other question is: whats the difference between mahogany and rosewood? everyone seems to have a preferance, but i don't know which i should buy.
Aboss
p.s. this is my first post on the forum! ...what an awesome idea this forum is, its been so helpful already and i only found it yesterday!
'06 Larrivee LV-03E
'03 Art & Lutherie Cherrywood
Welcome to the forum aboss.
Normally we require newbies to buy donuts for the 'old timers', but since you're a poor college student, the Larrivee Forum little sisters will bring out some donuts for you...
techie stuff. The -03 series Larrivee are the best buy out there today, IMHO. Of course an -05 or -09 is worth the upgrade to get the gloss and inlay. But the -03 series are fine playing and sounding instruments. And thats what its all about.
Hi and welcome.
mmmmmmmm.... donuts.
Anyways:
The 03s are great guitars. Personally I prefer the way they look. If cash is tight (even if it's not), it's a great option. I'll second the "best guitar at that price" comment.
Advantages of the 05 and above:
- Offer you more bling (gloss, abalone, etc).
- The woods are also more select as to visual appearance in the higher models (but won't necessarily sound better) and are matched (e.g. back vs sides) more carefully in looks; that said there's some great looking 03s out there and I personally think this distinction is rather unimportant.
- The only real differences that affect tone / sound are the different nut / saddle materials: tusq rather than bone. But this could easily and cheaply be swapped if you want to at some point.
- Also, some people complain of a swooshing noise on satin guitars when clothes on their stumming arm brush against the satin finish. This may not matter (though it might if you record a lot of strumming). That said, satin finishes can be buffed up to a near full gloss (which helps to avoid this). Search on orsonising / satin to gloss / etc.
Advatanges of the 03s:
Seems like I've talked up (over talked?) the advantages of the higher models. But just think, you could probably but a rosewood 03 and a mahogany 03 for the price of an 09 (especially if you went second hand).
As for mahogany vs rosewood, do a search on the forum, have a listen to the sound clips (pinned at the top of the larrivee forum) and have a look here: http://www.pantheonguitars.com/tonewoods.htm. Rosewood is a tad pricier but not better, just different. Ideally, try one of each and let your ears decide.
Most would agree that the L is the most versatile body. (Note that the D has a slightly slimmer nut width than other Larrivees). So I'm guessing L-03 or L-03R would be the ticket for you, unless you want / can justify the extra. You might want to think about whether you'd like / might need a cutaway (LV-03 / LV-03R).
I know it can be agonising: I went from thinking DV-03(R?) to DV-03(R?)/05/09 with custom nut width, and then eventually plumped for an LV-09 (no regrets). Of course, I then decided a mahogany guitar would be nice too....
Best of luck deciding!
Dan
Larrivees LV-09, L-05MT and P-03; Lowdens S-7 (1988) (FOR SALE), O-12 (2004)  and Baritone (2009); McIlroys A25c (2003) and A25c custom (2010); Sada Yairi Soloist (1965) - nylon string; Parker NiteFly with Roland GK-2a MIDI pickup; PBC superstrat and 5 string bass; AER Compact 60.
aboss.    WELCOME to the best forum on the net.
We can always count on someone like RandyR to bring the refreshments.    mmmm   mmmm   goood.     ^_^
The '03 series is a satin finish with no frills,  can be mahonangy or rosewood, or koa, and even some other exotic woods like my L03 Blackwood.
The '05 series will be a gloss finish with abalone rosette, Mahogany back and sides  (b/s)
The "09 serives same gloss finish and abalone,  but Rosewood B/S
All will have Spruce top wood.  all are solid woods  .  Most of us feel the "03 series lacks nothing for tone or playability, just less Bling!  :SHK>
So they may be the best value for your student budget     :ph34r:
For the sound difference 'tween rosewood and mahogany, you can check out the sound clips at the top of this fourm listing, and you can also do a search in the forum archives and read lots and lots of opinions and info about that.  You may want to make sure you do that search on a weekend with  no finals the next week.   ( sorry to be a dad, but my son is at school also, and I'm sure you wouldn't want to get swept up in your enthusiasm )   :GRN>
Welcome.
phill       :mellow:
Sorry for duplicate info,  must have been typing at the same time.
L-03 BlackWood..... "Pluck"
OM-03- MT Forum #14/17
F-III IS/Hog #63/78....SOLD
Seagull Artist Folk
Pono and Kanile'a Tenor Ukulele's
The real Day Sailer...1966 Day Sailer..the boat, not the person
To me, the best Larrivees are the LV-05 (better wood and trims than the 03, but essentially the same thing), OMV-60, SD-50/60 (both the 50 and 60).  So yeah, these are seriously worth checking out.  The other models are nice too, but they are not the ones that stand out like the ones I've mentioned, but that's just my view.  If you want an idea of how they sound like if you live in an area where they are not available, guitaradoption and indoorstorm has some sound files you can use to reference.  The indoorstorm files really brings out the realistic characters in these guitars, the guitaradoption mp3's are easier to make comparison (because they are the same riff).
BTW, i've actually never played an Larrivee Jumbo before, but I've heard really good things.  Fact is, the bigger the guitar, the fuller it sounds, but it's a trade off for comfort, style and practicality.
Larrivee LSV-05
Larrivee LV-09FM
Larrivee CS-30
Yamaha Chronos LL-16
Yamaha Pacifica 112J
Martin LX-1
Fender American Stratocaster Delux
Fender Mexican Stratocaster
Fender Mexican Telecaster
Rivera Sedon
Hey aboss.  Like you, I played everything in the 03 price range (and even mistakenly initially bought something else under the spell of the big "M" name and probably in my miserly mode, trying to save a few bucks, but I wisely traded it in for the L03 subsequently) - I really don't think anything else compares for all the reasons we love Larrivees - quality, balance, features, playability.  I also had the chance to play 05s, 50s, 60s, in mahogany and rosewood.  even with my less than discerning ear, I could hear the differences across sizes, styles, and woods  . . . but from series to series, the quality struck me as uniformly high.  I hope you get a chance to play some more Larrivees to experience this for yoursellf.  (I think my observations are consistent with what others have posted here, too.)  It boils down to personal preference - and I liked Mahogany and the L-size, and I am perfectly happy with the satin finish, so went with the L03.
What does all that mean?  I don't have specific advice to offer.  If there is something that you want for a few hundred more (glossy finish or whatever), the 05's and up are great - if you want the "traditional" sound of the 50s and 60s, those are great guitars too.  For me,after two months with my L03, I love it - love playing it and am becoming a better player because of it.  I would never need to upgrade for playability and sound reasons - and I really think if this were the only acoustic - for that matter, the only guitar of any type - that I would ever own, I'd be very happy with it.   But I am easily influenced by all these multiple-Larry owners here, so i suspect I'll add a D50 and/or a D60 and/or a 12-string Larry down the road.  But I'd never part with my L03.  :-)
Thanks for the donuts, Randy. Always good hospitality here. . . .
Aboss:
Welcome aboard.  I just discovered Larrivee guitars a couple months ago myself and I'm new around here too.
QuoteI've checked out all the lower end martins, taylors etc. the usual suspects, and i have been unimpressed with them. (The taylors are pretty good, but i can't figure out what the obsession with martin is. Everyone says they are the best... but the ones i've played have had very little character. not impressed at all.) Then i came across the larrivee L-03. Wow. what a guitar. it sounds and plays better than most guitars i have played that cost more than twice as much! I keep going to various guitar stores trying other guitars... always trying to figure out why the larrivee seems too good to be true, but nomatter what i compare to it, the L03 always comes out on top.
You've done the research and have found that Taylors are over-priced for what they are, Martins often don't sound good off the shop wall because of poor string quality and some of the other usual suspects are too expensive or have questionable character.  It helps everyone to hear a new players' objective opinion.
A lot of us have owned many guitars over the years.  Some of us currently own guitars from all three majors (Taylors, Martins and Larrivees).  Everyone has an opinion so here's mine:
There are several "best values" in the Martin and Larrivee line.  Price point comparisons show that Larrivee is the better value.  Martin is second.  And Taylor doesn't have a price point comparison with Larrivee.  They're just over-priced from the gitgo.  Again, this is my opinion.  It's not Taylor bashing at all.  Some Taylors sound exceptional.  Most do not.  I own one that does.  It's a custom Koa 12 series from 1993.
The best value in a Martin is the 000-15S.  It's all mahogany, no binding, decal rosette.  'Very woody-sounding and versatile.  Depending on how you set the action, it can be used for fingerstyle as well as flatpicking.  A comparable Larrivee is an all Mahogany OM.  These two guitars would have similar price points but different configurations.  Check out the 000-15S.  I don't know as the Larrivee OM hogs are made anymore? ? ? ?
The best value in the Larrivee line is the -03 series.  Solid wood, maple binding, satin finish, decal rosette, bound fretboard.  A Martin with comparable features might cost $1800-$2000.
ANY guitar you buy will probably need some tweaking and a set up to acommodate your style of playing.
Take care.
Larrivee OM-03R-12 string + IMix external
Martin 000-15S + IMix internal
Martin OM-16GTE + Fishman Matrix
Gretch 5120
Fender Squires - Tele & Strat
whiskeyjack:  Perisoreus canadensis.  aka, gray jay, whiskey jay, whiskeyjack or timber jay.   A small, friendly bird of the northern coniferous forest.
